Old 12-12-2007   #30
Re: Cold weather = bad gas mileage?
and BOOM!!
Had a question about heat coming into the car from the heater. It seems like my car is always kind of cold. It doesn't get truly warm until it is on the highway. I mean I get heat out of the car pretty soon but not hot temperature like it is on the highway. I removed the A/C condenser because of weight and that opened up the radiator for more cooling. Did that have anything to do with it? Do I have a bad thermostat or is the engine running that cool when around town? Coming off the highway it stays warm.
Fluid level is good also.
Check your coolant temps via logger. You should still get to operating temperatures, but you could have a failing t-stat.
