Old 12-13-2007   #32
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 95 talon awd
just replaced ALL the belts less then a month ago...
So i sould put a bar of soap under the belts as its running?????
Obviously if tightening the alt. belt doesnt work i mean???
Well that might solve it for a little bit but using a bar of soap everytime the car squeels seems kind of dumb to me.
On a date,
"Excuse me for a minute, my cars belts are squeeling. Do you have a bar of soap I can use?"
Just use the soap technique as a tool (same as belt dressing, doesn't matter which one you use)
After checking to see if both belts are tightened
Apply it to one belt, if it doesn't stop
apply to second belt
If the squeeling stops on the belt, you know which one is giving you problems.
If it doesn't stop, replace belts and see if that stops it
How long have they been squeeling? You could have burned through one by now. still don't rule out the alternator.
