Old 12-20-2007   #4
Re: Garage Options.
Originally Posted by AJ View Post
I never thought about a floor drain, may have to ask about that one.
You won't regret it.
As for heating I am thinking of just adding insulation up in the roof and then in the walls and then rock it. Then put in a larger heater up in a corner at some point. I never thought about in floor heat and I wonder how much more that would be.
I'd check with your insurance company on their garage heat policies. I know that Farm Bureau is very anal about what is acceptable for garage heating.
On anoter note, I am going to have it wired up for 30/50 amp (not sure which it is) so I can have an air compressor in there and at least have the ability to run a welder and such if it ever came about.
Have you considered having your garage on a separate power supply from the grid? Then you can really "crank the juice" to your garage. I wanted to put my garage on a separate supply until I found out that my power supply is in-ground versus aerial (i.e.- major $$$$).
