Old 01-28-2008   #2
Re: another 6 bolt swap Q
I was told to use all the 2g sensors on the 6 bolt motor.
2g TPS (has 4 pins vs 3), oil pressure, water temp sensors, knock sensor, etc.
The exception would be the 1g CAS which hooks up to the 2g plugs for crank/cams.
I'm not sure if any are the same between 1g and 2g, something like water temp or oil pressure may not have changed.
