Old 01-28-2008   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: weird problem
How can you tell if it is running rich? (Wideband??)
Have you tested your ECU with another one? (may be bad but not visable)
Did you pressurize the air system? (Real boost leak tester)
What injectors and tuning method?
What gas and how old?
Your 02 sensor melting may of damaged the ecu with wires all touching and shorting out other areas of the ECU or wiring harness itself
Amsoil Dealer
