Old 02-06-2008   #15
iceminion
iceminion's Avatar
Re: Supplemental Air Suspension, how should it be done?
Ok, since the driveway issue is "solved" how about the huge speed bumps at my friends apartment that scrape my intercooler?
Second, if designed properly, there would be no change in the suspension during normal driving, I would only be using this system for situations where I need to go over a bump!
Yes, several hundred thousand dollars has gone into the development of supercar front ride height adjustments, I think I can do something similiar for a fraction of that.
ok, changing gears, after looking at how little room there is between the frame and the wheel....what about 2x of these? http://www.firgelliauto.com/product_...products_id=59
anyone with just reason why these wont bolt on with minimal fabircation of brackets? possibly a rubber damper as to releave stress on the actuator itself?
changing oil could be pretty easy if i could just lift the car up by flipping a switch! LOL
building a 3000GT AWD Turbo.
