Old 02-20-2008   #37
Re: Buschnuts calls out Magnus
Why was the old design teh ghey? Because Buschur found out it makes less HP than a stock one at low RPM's? That should be a given with aftermarket intakes.
That's the thing. The other intakes they tested did not loose 40whp down low, just a little bit of spool.
Check this thread for the straight results/facts:
http://buschurforums.com/forum/showthread.php?t=20866
The hypertune came out roughly on top; almost zero loss in spool or low-end torque, and lots of power gains up top. Still, a ported stocker w/ 65mm TB will bump 10-15whp across the entire powerband, and $375 vs $2200 is tough to swollow for an extra 10-15whp up top.
