Old 02-29-2008   #1
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
clutch issues
I have a 91' eagle talon awd im having a problem where when i first start it, it will easily go into gear. Once you engage the clutch it wants to hop as if the clutch wasnt all the way engaged. I replaced the clutch/throw-out bearing about a month ago and the master cylinder is new as of today. Question I have is does anyone have an idea of what it could be? Im afraid it might be a problem with the throw out bearing because im having similar issues as i was when the clutch went out.
One question I have is.. how far should the push rod on the master be screwed into the actual clutch pedal itself?
Any help would be appreciated Thanks.
-Matt
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
