Old 03-17-2008   #2
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Timing Parts 6bolt - 7bolt. Are they the same?
I've always interchanged parts and never had any issues. Not saying this is correct or not but it has always worked for me.
The only real difference I see is the back plate and the timing belt cover.
Make sure you set the motor to TDC when putting the backing plate on and the marks line up. If you put it on backwards you could bend some valves. It can go on either way, just make sure the way you put it on is correct.
Originally Posted by shoutbox
