Old 04-22-2008   #12
Supa_dupa_man
Bimmer Guy
Supa_dupa_man's Avatar
Drives: ///M3
Re: HELP! Gas is comming out my exhaust!
Ok guys, here is the newest update... Before the most recient rebuild I was using an AEM F/IC on the car while running Crane 0018 cams... The motor blew, I sold the AEM, to get money to fund my turbo kit build up (Decided to rock manual fuel tuning) I rebuilt the motor and I am still using the 0018 cams... however, you can only run these cams with a Air and Fuel controler, or an electronic Fuel management unit. So this means I have to downgrade my cam size or get another AEM F/IC...
Jungy and I are going to swap cams this Friday, he has the 0014s. After I install the 14s I will see if my problem is fixed, If not, I will have to replace the HG, and check for any other damage...
But according to research, the cams seem to be the problem...
MMFTW
Supa_dupa_man is offline   Reply With Quote
