Old 04-23-2008   #1
kennydawgg
Wink 4g64 parts
ok i have some parts that can disappear out of my garage. they are all off a 98 SOHC 4g64 -spyder gs
Stock exhaust manifold
catback with muffler
SOHC head
intake manifold
bumper reinforcements
Stock oil pan
Stock Springs
Oil pump ~gear is broken from my destructive disassembly but the pump works
lower cover that the balance shaft comes out with ~not sure what this is called, let the beatings begin . .
I might pull the ac system out as well if someone is interested and the price is right, the jury is still out on if i want to keep this.
4g64 block with a hole in the side and a 7bolt 4g64 crank that is real bad on two journals possibly fixable ~ no one wants this but I thought I would add it in case someone scraps stuff but if you take one you take both.
everything is b/o if you wanted to take a partial trade plus cash towards a set of injectors (650+) let me know.
kennydawgg is offline   Reply With Quote
Old 04-23-2008   #2
bob123131
Re: 4g64 parts
Do you have the two rods and pistons from the 7 bolt block journals that were not totally ruined?
Old 04-24-2008   #3
kennydawgg
Re: 4g64 parts
I have one, I have to use the other one for my current build
