Old 05-13-2008   #19
Re: Dual Walbro's in a 1G AWD
Yes I understand by rewiring, you may see an extra 2 volts or so at the fuel pump, allowing it to flow more. I did this on my old 2G 7 years back. It's a great mod if you are pushing the pump. But do you think I'm going to need those extra 2V in this case? Am I going to require more then what 2 255hp's put out at 12V? I honestly don't think so. Guys have ran SC61's pushing a single 255 to it's limits. 2 255's won't flow double, but will flow quite a bit more then a single. As of right now I really don't think I need to rewire this because I need that extra 2V for more flow. But again, what about amperage? Adding a 2nd pump just doubled the amperage the stock wiring will be seeing. That's what I'm worried about, too much amperage on the stock wires. I may just end up rewiring it because I don't want to pop a fuse and lose power to the pumps during a 30psi pull. That'd make for a real bad day
