Old 05-16-2008   #2
Re: Help Me!!!
If everything is working properly the sunroof should not leak no matter what. BUT, with that said, Mitsubishi makes really crappy sunroofs than leak wind noise and water after only a few years sometimes. You can try greasing the seal with some grease, but more than likely you're going to need a replacement seal.
This is a good time to mention to everyone:
Keep your trunk, hood, sunroof, door, and window seals greased! This will help prevent wind and water leakage as the seals age. Honda sells a good grease call Shinitsu that works well.
