Old 06-11-2008   #2
v8klla
v8klla's Avatar
Re: MAPerformance Inventory Clearance Sale *Updated / More Items*
NGK Copper Spark Plugs / WRX / Heat Range 7 (1)
NGK Iridium Spark Plugs / WRX / Heat Range 7 (4)
NGK Iridium Spark Plugs / WRX / Heat Range 8 (4)
NGK Iridium Spark Plugs / DSM & Evo VIII / Heat Range 7 (4)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 7 (1)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 8 (1)
NGK Iridium Spark Plugs / DSM & Evo VIII / Heat Range 9 (4)
NGK Copper Spark Plugs / DSM & Evo VIII / Heat Range 9 (1)
NGK Iridium Spark Plugs / STi / Heat Range 7 (4)
NGK Iridium Spark Plugs / SRT-4 / Heat Range 6 (4)
Perrin Performance Shorty Antenna 4" Evo VIII/IX
Perrin Performance Fuel Rail Upgrade System / Red / Evo
Perrin Performance Front Mount Intercooler System / Evo
Perrin Performance Front Mount Intercooler System / Stealth / Black
Perrin Performance SS Downpipe / 3" / Evo
Perrin Performance 3" Cat Back Exhaust System / Evo
Perrin Performance Catback Exhaust / Stealth / Evo
Perrin Performance Adjustable Endlinks / Rear / Evo
Perrin Performance Front Mount Intercooler Kit / WRX & STi
Perrin Performance Radiator Shroud / WRX & STi / Black
Perrin Performance Downpipe / Front Section / '06-'07 WRX
Perrin Performance Downpipe / Rear Section / '06-'07 WRX
Perrin Performance Sport Tone Exhaust / Single Tip / Stealth / WRX & STi
Perrin Performance Afta-Maf Tube / WRX & STi / Black
Perrin Performance Intercooler Hose Kit / Drive By Cable
Perrin Performance Recirculating Blow Off Valve / Black / WRX & STi
Perrin Performance Recirculating Blow Off Valve / Red / WRX & STi
Perrin Performance Sway Bar Kit / STi / 22mm / Front and Rear / Includes End Links and Mounts
Perrin Performance Endlinks / Front / WRX & STi
Perrin Performance Sway Bar / 22mm / Adjustable / WRX
Perrin Performance Sway Bar / 25mm / Rear / STi
Perrin Performance Rear Endlinks / 93-07 Impreza & WRX
Perrin Performance PSRS / WRX
Prosport Mechanical Boost Gauge / 30psi / Blue
Prosport Mechanical Boost Gauge / 45psi / Blue
Prosport Electronic Boost Gauge / 30psi / Blue
Prosport EGT Gauge with Sensor / Blue
Prosport Water Temp Gauge with Sensor / Blue
Prosport Air/Fuel Ratio Gauge (Narrowband) / Amber-White
Prosport Mechanical Boost Gauge / 30psi / Amber-White
Prosport Electronic Boost Gauge / 30psi / Amber-White
Prosport EGT Gauge with Sensor / Amber-White
Prosport Oil Pressure Gauge with Sensor / Amber-White
Prosport Oil Temperature Gauge with Sensor / Amber-White
Prosport Water Temp Gauge with Sensor / Amber-White
Prosport Mechanical Boost Gauge / 30psi / Green-White
Prosport Electronic Boost Gauge / Green-White
Prosport Exhaust Gas Temperature Gauge with Sensor / Green-White
Prosport Fuel Pressure Gauge / Green-White
Prosport Premium Series Electronic Boost Gauge / Amber-White / Units=Bar
Prosport Premium EGT Gauge with Sensor / Amber-White
Prosport Premium Oil Pressure Gauge with Sensor / Amber-White
Prosport Premium Electronic Boost Gauge / Green-White
Prosport Premium Water Temp Gauge with Sensor / Amber-White
Prosport Oil Filter Adapter Plate / Subaru, Honda, Ford, Mazda, Mitsubishi
Prosport 52mm Mounting Cup / Black Plastic
Precision Turbo Inlet Turbine Gasket / T3
Precision Turbo Inlet Turbine Gasket / T4 Open
Precision Turbo Inlet Turbine Gasket / T4 Divided
Punishment Racing T3 4 Bolt O2 Housing / Stainless Steel
QuarterMaster Flywheel / 7 Bolt DSM
Quaife Front Differential / Evo 8 & 9
Redline MTL Gear Oil
Redline MT90 Gear Oil
Remflex Universal 3" / 2 Bolt Gasket (4-1/8" Spacing)
Royal Purple 5w30 Synthetic Motor Oil
Russell AN to Metric Adapter Fitting / -6 AN to 14mm x 1.5 Male / Straight
Samco Sport VW Golf Mk4 / Beetle / Audi TT 180 / Seat Leon / Skoda Octavia Turbo Induction (Red)
Scat Enterprises Connecting Rods / 6 Bolt DSM
Summit Brand Weld In Aluminum Bung / -6an
Tial BOV Weld Flange / Mild Steel
Topline Complete Block Gasket Set / 7 Bolt DSM
Topline Complete Block Gasket Set / 6 Bolt DSM
Topline Complete Gasket Set / 1g 7 Bolt DSM
Topline Complete Gasket Set / 2g DSM
Topline Complete Gasket Set / 6 Bolt DSM
Topline Freeze Plug Set(Nine 35mm Plugs / DSM
Topline Exhaust Valve Guides / DSM (Set of 8)
Topline Head Gasket Set / 1g 7 Bolt DSM
Topline Head Gasket Set / 2g DSM
Topline Head Gasket Set / 6 Bolt DSM
Topline Intake Valve Guides / DSM (Set of 8)
Topline Revised Lifters / DSM & Evo (Set of 16)
Topline Oil Pump / 6 Bolt DSM
Topline Pistons with Rings Set / Standard Bore / 6 Bolt DSM
Topline Pistons with Rings Set / .020" Overbore / 6 Bolt DSM
Topline Water Pump / 1g 7 Bolt DSM
Topline Water Pump / 1g 6 Bolt DSM
Trick Flow Hose End / Black / 90 Degree / -8 AN Hose to Female -8 AN
Venair 2.5" to 2" Reducer Coupler
Venair 3" to 2.5" Reducer Coupler
Venair 2" 90 Degree Elbow
Venair 2.5" 90 Degree Elbow
Venair 3" 90 Degree Elbow
Venair Straight 2" Coupler
Venair Straight 2.5" Coupler
Venair Straight 3" Coupler
Vibrant Performance SS O2 Bung
Vibrant Performance O2 Plug
Vibrant Tial / Ultragate (oval 2 bolt) Wastegate Flange, 1/2" Thick
Vibrant T304 Stainless Steel Tial / Deltagate / Turbosmart 35-38mm External Wastegate Flange (Ta...
Vibrant 35-38mm External Wastegate Flange w/ Tapped bolt holes (3/8" thick)
Vibrant 4 bolt GT30/GT35 Discharge Flange / 3" I.D. / 1/2" thick / SS
Vibrant 4 bolt GT30/GT35 Discharge Flange / 3" I.D. / 1/2" thick / Mild Steel
Vibrant 4 bolt GT30/GT35 Discharge Flange / 2.5" I.D. / 1/2" thick / SS
Vibrant 4 bolt GT30/GT35 Discharge Flange / 2.5" I.D. / 1/2" thick / Mild Steel
Vibrant 2-Bolt Stainless Steel Flange (2.5" I.D.)
Vibrant 2-bolt Stainless Steel Flange (3" I.D.)
Vibrant Performance 4 Ply Reducer Coupling, 2.5" x 3" x 3" long - Black
Vibrant T-Bolt Clamp / For use with 2.75" couplers
Visteon Aluminum Radiator w/Spal Fan / 2g N/T DSM
Walbro Installation Kit / '84-'92 Toyota Supra Turbo
Walbro Installation Kit / '89-'94 Nissan 240SX
Walbro Installation Kit / Subaru
Walbro Installation Kit / '94-'00 Acura Integra / '92-'00 Civic & Del Sol
Walbro Installation Kit / 2g DSM & Evo
Walbro Installation Kit / '89+ Mazda RX7
Walbro Installation Kit / 1g AWD DSM
Walbro Installation Kit / '97+ Honda Prelude
Walbro Installation Kit / 1g DSM FWD
Walbro Installation Kit / '90-'93 Acura Integra & Honda Accord
Walbro 255lph Fuel Pump / SRT-4
Walbro 255lph HP Fuel Pump
Whiteline Steering Rack Bushing Kit
Wilwood PolyMatrix E Compound Brake Pads / Dynalite Single Front Axle
Wiseco Pistons / 7 Bolt 4g63 / 86.5mm Bore
Wiseco Pistons / 6 Bolt DSM / 2.0l / 86mm Bore / 8.3:1 CR
Wiseco Pistons / 7 Bolt DSM & Evo / Standard Bore
Zeitronix 5 Bar MAP Sensor
Zeitronix EGT Probe and Extension Harness
Zeitronix Black LCD Wideband Bundle
Zeitronix ZR-2 Wideband Bundle (Blue)
Zeitronix ZR-2 Wideband Bundle (Red)
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
