Old 03-13-2004   #14
PSI2HI
You can check the cam/timing belt alignment w/o taking anything apart. Line the gears up to TDC check the timing marks on the crank pulley. Your timing mark should sit @ 0, if not you got a misalignment problem.
Nick
Straight Line Specialties
