Old 06-28-2008   #11
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Getting the Laser ready for AutoX
Spray wash it off or soak it in brake cleaner to get it semi clean and get rid of all the fluid and dirt around the seals then check for where its leaking.
Axle seals do tend to leak, the more times they are messed with, pulling the tranny in and out, replacing axles and such, the more they tend to leak.
Axle boots are simple to replace also, just rip the old one the rest of the way off, pull the clip holding the CV joint onto the axle and remove it. Clean everything up good, slide the new boot on, crimp the small band first, put the new packet of grease into the CV cup, slide on the axle, put clip back on, and tighten down the large band.
If you dont have the tool to crimp the bands, I do. Just let me know.
Originally Posted by shoutbox
