Old 07-13-2008   #10
Re: Finally, Dyno Results!!!
His kit has a flow based failsafe, incase the pump is failing or the tank runs dry, I believe. And I think he has it wired so that if the main unit loses power that the ECU switches to the pump map. He shut it off during one run and it changed to the pump gas map without even a lean spike or anything.
