Old 07-13-2008   #1
Re: Finally, Dyno Results!!!
Yup, I love alky injection and wanted to see what it can do for me, and really work the technology behind this mapswitching stuff with the stock ECU. I'm *very* happy. I saw my car pick up 10whp with 1-2* of timing increase on the dyno, but it wanted to knock a bit during those pulls. So, I plan on now taking these base numbers and trying out different mix combos of alky/meth/water to see if I can run more timing.
I have enough injector now for E85, so that will come in due time. Now that I have wideband in-car, it's more about me playing with the different alky mixes and doing seeing what I can do with the car. Then it's up to shane to really make it soar....or sore if it's way wrong :P
MattD, I didn't catch the diff b/w Street Modified and Street Prepared earlier. Alky can be worth just as much as cams, so it's crazy it's allowed. Aquamist HFS-5 is probably what you want, although you can start with an HFS-1 and see how you like it
Old 07-13-2008   #2
Alky can be worth just as much as alky
Stop sniffing the alcohol.
