Old 08-08-2008   #10
Re: WTB: an experienced technicians help
Originally Posted by slowboy View Post
Well you're converting the airflow signal to compensate for the bigger injectors right? So the engine thinks it has about 30% less airflow than it really does? Someone correct me if I'm wrong, but I believe that will mess up your timing so you'll be more prone to knock.
Correct,
The reduced airflow % will lead to a lower "engine load" demand in the ecu's timing tables.
So instead of grabbing the top load row of timing values, say 11 degrees, the ecu thinks it is at 65% load and grabs 20 degrees, which will lead to detonation.
That is why it is crutial that your airflow % correction match your fuel needs as close as possible, should be +/- 15% at WOT, idealy.
