Old 08-17-2008   #17
Re: Fuel Cut #3
Did another boost leak test, found the TB shaft seals were leaking and two of the injector seals were pretty bad. I replaced all four injector seals, and I also flipped the fuel cut switch on the MAFT to allow factory fuel cut. (I misplaced my Instructions for the MAFT, so according to Tuners it's switch #3 needs to be in the down position, maybe someone can confirm that)
I just don't get why no one else has problems running 15psi on the stock fuel system/ecu.
