Old 08-18-2008   #10
Andres06SE
Andres06SE's Avatar
Drives: 06 Mitsubishi Lancer Evollution SE
Re: I can has suspensions
Installing the swaybar seemed like it was going good until it came to remounting it. This unit reuses the stock brackets and replaces the bushings with harder ones. The way the stock brackets work is just fine, but the aftermarket bushings just mess that all up. If you do get this swaybar I suggest looking into a different mounting bracket as well.
So what did you end up doing? using the stock bushings?.Looks great
Andres
Andres06SE is offline   Reply With Quote
