Old 09-02-2008   #10
Re: HTA turbos what they are cracked up to be?
Well to degree cams you need: the cam card for your cams, solid adjustable HLAs, a degree wheel, a pointer to indicate TDC, a few Dial indicators with special attachments to read the lift of the valve off the retainer, and a few hours of your time. We can talk about labor time if you want? This would make the cams do what the cam card says they should do, if thats what you motor needs to make power I do not know. Another and longer process would be adjusting them on a dyno to find a good power band for the setup, be happy you only have 2 cam gears to adjust, 3000gt's have 4. I did not know your head was stock, buy a stage 3 head or pay someone who knows what they are doing to port it, I would not try it your self.
