Old 03-23-2004   #6
Originally posted by blown_turbo_tsi@Mar 23 2004, 10:42 AM
i thought that the cas adjusted itself? if you were to just put it somewhere in the middle wouldn't it work by itself?
sorry.... still a newb to dsm's as well as just about all other imports
The ECU adjust timing advance/retard on its own depending on certain conditions, but there is a baseline that the ECU goes off of. If the CAS isn't aligned properly then the rest of the timing adjustments will be off also.
