Old 10-22-2008   #36
Re: Engine Clanking -WTF!!!
OK got the ring measurements from MAP.
Now, I'm looking at cleaning the crap out of the motor with some contact cleaner, and then begin reassembly. I have NEVER done this before, and I have questions.
1: The old rod bearings looked pretty decent, but I bought new ACL Race bearings that I want to throw in anyway just to be safe. What do you guys use to lube them? I've read everything from just oil, to moly lube, to white lithium grease. And do you lube both sides of the bearings? Also, I keep reading that you have to check the bearing clearance, but I have never used plastigauge before either. Anyone care to try and explain? Then if I figure out how to use it, and the clearance is wrong, well then what the hell do I do?
2. Do I need to lube the cylinder walls and piston skirts? Remember that 3 of these are still the same pistons/rings that came out, and are going right back in without any changes.
3. Do I have to lube the piston/rod pin before I put it in?
