Old 10-26-2008   #5
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Injectors?
You cant just drop in different injectors and expect them to run. Bigger injectors=more fuel which is why it wouldnt run for crap. You have to compensate to make it run on anything bigger then stock. Also how do you know that you are not running lean on the stock injectors? You will not know this unless you have a wideband or have dyno'd your car and have a wideband print out from that.
Amsoil Dealer
