Old 10-27-2008   #3
Re: hks adj cam gears, issues with setting up timing. Help
Setting the cam gears to 0 on both, might help to make sure they are lined up right. You could set them back to their current setting, if thats what it was tuned for after you get the timing belt all lined up. Then run a straight edge across the bolts and center marks and make sure the line goes through the center of the bolts, not the very top or bottom. The marks on the top of the cam gears are for an Evo, so ignore them.
