Old 11-06-2008   #4
GnArKiLl
GnArKiLl's Avatar
Re: car keeps stalling.. and im stumped!
Bad idle motor? Is the MAF after the BOV? If the car is fully warmed up and just idling while sitting still, do the RPMs go down when you push the clutch in?
yes the maf is after to bov.. and yes the rpms go up and down with the clutch..
You said nothing about fuel control in your mod list, what are you using to tune it? Are you just using the MAFT? If you are still using the auto ECU, remember that it is programmed for 390cc injectors. What fuel pressure are you set for with the afpr (with the vacuum line off)?
im using the maft and safcII.. and im using a 92 5spd eprom, also have it set to stock 5spd fuel pressure..
also i do have idle surge..
