Old 01-08-2009   #6
Re: Base fuel pressure adjustments
I meant that the deadtimes affected it a lot at idle, often more than anything with huge injectors, I had just worded it poorly above.
Here is the formula to find injector flow with changes in base fuel pressure. Injectors are usually rated for 43.5psi.
SquareRoot(New Fuel Pressure / Old Fuel Pressure) * Old Injector Flow in CC = New Injector Flow in CC
SQRT(40psi/43.5psi)*1600cc=1534cc
1600/1534 = 4.3%
1534/1600 = 4.1%
