Old 02-04-2009   #11
Re: Clutch Low Engagement(yea, I know it's a DSM)
Originally Posted by desolate View Post
If pumping builds the pressure, then it would probably be worn out cylinders master or slave.
+1 absolutely. If you can pump it and solve the problem, it's a cyl problem. Replace the slave first, it's the most likely to fail. If that doesn't fix it, then do the master. Do both if you wanna *ghasp* do some preventative maintenance!
