Old 02-10-2009   #25
Re: Name change!
hence why I got tomorrow off to make the upper ic pipe, clean up some wiring, check grounds, finish the timing belt and cam gears, start to put it all back together. WG is ordered and on the way, injectors are in, i just need to take out the old gas, get e85, and hcange the map around..anyone know when MN goes back to the "good" mix of e fuel?
-A. Swift
