Old 04-01-2004   #3
The pulley is easy, but doing the balance shaft belt which requires taking off the plate behing the large crank bolt can be a bear. I've had to heat up pulley bolts with Mapp gas and using a 600 ft/lb impact gun to get them off. Good luck.
