Old 02-14-2009   #10
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Getting the Laser ready for AutoX
With my tax returns officially on the way in, I can start planning and gathering things for 09. I want to actually be able to have a chance at winning SM in my local SCCA region, and the most cost effective way of doing so is new tires. So I picked out 4 brand new Falken Azenis RT-615's from discount tire direct. They will be mounted on some stock rims.
Next, I will be converting from the 1g Maf setup to a 3 inch gm maf setup with a translator. This will diffinently help in so many ways right now I can't even begin to go over all of them.
I will also be changing transmissions, so I'll be picking up a new XTD Stage 3 6 puck clutch kit off ebay. I Still have the 1g Nt tranny that came with the car, and I know it doesn't leak. Not only that, but it has shorter gear ratios as well. The current turbo tranny that I had put in sounds like its on its last legs.
And lastly, I'll be going through the engine bay fixing leaks and once I got the leaks fixed, I'll take it into work on a weekend and spray out the engine bay with the pressure washer.
I do hope to make the spring cruise, but right now it's up in the air.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
