Old 04-04-2004   #2
FORSFED
The 7-bolt pistons use a 22mm pin where the 6-bolt use a 21mm pin. If you want the 2g pistons on your 1g rods, the rods need to be machined to accept the larger pin. Otherwise they both have an 85mm bore and depending on the wear on your cylinder walls, you shouldn't have to go oversized.
