Old 03-21-2009   #22
Re: 4b11t going into new RWD Hyundai coupe
found this:
Hyundai Genesis 2.0L Turbo & Differences
There seems to be a lot of buzz starting regarding the coming Hyundai Genesis coupe. Hopefully it will be a solid foundation that people can easily modify and beat the crap out of without breaking too easily. Anyhow, last week I was working on the 32 over at XS and Gary from Design Craft stopped by in a blue decked out Genesis 2.0L turbo. He already had it decked out with wheels, Stoptech brakes front and rear, custom Apexi coilovers, Turbonetics turbo, intercooler, Sparco seats, Design Craft custom roll cage, etc. It turns out its a 0-60 Magazine project car so look out for a future issue of 0-60 for details on the car (bitchin mag btw).
I have read here and there where people are claiming that the Mitsubishi and Hyundai versions of the 4B engines are nearly the same. So to clarify, here are some factual things I’ve learned from talking to Gary at Design Craft (who would probably be the leading Hyundai 4B11T expert at this point in time), Simon at Hyundai (who is a Hyundai test engineer and probably knows the most about the Genesis Coupe at this point in time), and Mo at Mitsubishi (who just knows a lot about both versions of the 4B11T and a certified car nut himself) about the Hyundai Genesis Coupe and it’s engines:
1. The Hyundai 4B11T is not the same as the Mitsubishi EVO X 4B11T. While the Hyundai 4B is similar in many ways, there are very few common parts. The block, head, pistons, rods, crank, etc. are all similar, but different. Different in that they are lower grade. Hyundai’s rods are powder sintered whereas Mitsubishi’s are forged. Mitsubishi’s pistons are made by Mahle and have a oil reservoir underneath the dish like a Porsche turbo piston. Hyundai’s cast piston is no different in strength compared to one of their passenger cars. Hyundai’s 4B block has far less webbing (this is visible from the exterior). The differences go on and on. That doesn’t mean the Hyundai parts suck. It’s just that the Mitsubishi 4B11T is way better out of the box. While the parts are different, that doesn’t mean that the Mitsubishi pistons, rods, and crank cannot fit into a Hyundai 4B.
2. The cylinder head is different enough that the exhaust manifold and intake manifold flanges and gaskets are not common. They are absolutely different so there will be no manifold and turbo swapping. This is an absolute fact since Gary tried fitting the manifolds from an EVO X. The Mitsu engine is mounted transverse and it is very likely that the castings wouldn’t work anyway. That’s too bad since the Cosworth EVO X 4B11T CNC ported big valve cylinder head will be available to the public soon. See #6 below on the cams.
3. The LSD in the sports version is a gear type LSD and not a clutch type.
4. There is an orifice in the clutch’s hydraulic plumbing that needs to be removed for performance purposes (as do many other cars).
5. The Hyundai V-6 is very similar in design to the Nissan VQ35. If you’re going to make a new V6, you’d be a fool not to copy, oh sorry uh….model your new engine after the VQ35 since it is the best damn V6 in production right now.
6. While the cams are SIMILAR in appearance, they may not be identical like the GenesisDriven blog states. The blog post states that their Korean source says, “With your pictures send to Korea, our engineer and tech dept. have confirmed its identical as 2.0 turbo Theta for those cams.” I’m not sure what kind of engineer looks at a picture on a computer screen, makes a foolish assumption, and says, “Yep, those are identical.” I don’t think I want that engineer designing my parts. Regardless, the Hyundai and Mitsu 4B11T camshafts need to be precisely measured before saying that they are “identical”. I sure hope they’re the same because Cosworth already offers the best damn EVO X cams that money can buy.
7. (added 3/13/09) The ECU is made by Siemens. I wonder who’s going to get in on the reflash crap first? Or better yet, who’s going to make a proper standalone ECU?
