Old 03-24-2009   #5
Re: Twin stock fuel pumps? :O
You'd rather go through the trouble of buying stuff to make the 2 pumps work than to shell out $50 for a used 255 or something?
You'll need the T-fitting (mine was a 3/8 fitting that cost somthing ridiculous like $10 from Ace). You'll need some fuel line, fuel line clamps, and some hose clamps clamp the dual assembly to the sending unit, wire, wire crimps, and that's probably about it. If you shop around, or if you have some of the stuff already, you might not have to spend that much.
But like Cher said, a used 255 isn't all that much, and you know it'll still flow somewhat decent at higher pressure levels.
Good luck with whatever you choose.
