Old 04-04-2009   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
FS: 1991 Talon TSI auto. Bone stock
Well it’s time for me to sell my panda. The car has been really good to me considering I’ve driven it from Chicago to Minneapolis 7 or so times and never encountered a single problem. The car is bone stock other than the emissions being removed. It has 145,2xx miles on it. I’m just looking for something more fuel efficient. This car does get on average 23mpg but I’m looking to get a Honda since I drive back and forth so much. It’s got all maintenance done and ready to go!
The good:
Converted to all 5 speed stuff (cams, ecu, injectors, fuel pressure regulator, 14b turbo with 7cm housing)
2g exhaust manifold
New radiator
All new coolant hoses (along with new coolant)
All new belts including timing belt
New brakes
New water pump
New spark plug wires and plugs
New ball joints, axle, tie rod end
Autometer boost gauge
Body is in excellent shape with no dents
New headliner
New fuel filter
New front speakers
New transfer case and rear diff fluid (mobile1 synthetic)
Power windows and locks
Sunroof DOESN’T leak
New tabs
The bad:
2 spots of rust. (driver side rear quarter panel, driver side front fender) Very easily fixable, barely showing through paint.
Bottom of front seats are torn up a bit
Rear hatch struts don’t work (obviously)
Has ABS but the fuse was pulled (I don’t consider it a bad thing)
Key only works in driver’s door
Bottom part of throttle body is blocked off. Still kept the ISC motor. (fixed idle surge)
Oil cooler is by-passed
This has been a very good daily driver for me and I’d love to keep it, but like I said I need something that gets better gas mileage. I have gotten many compliments on how clean it is. I am not looking for trades unless you have a very fuel efficient reliable car. I’m looking to get $2,700 OBO.
My name is Andy Nash and you can call/text 651 247 5990 for more info.
The car is located in IL with me right now but I do come back to MN every other weekend or so if anyone wants to come take a look at it. Also it will be coming with stock wheels with brand new tires if price is met. Otherwise some steelies with pretty decent tires.
UPDATE: Vid of me driving the car around
http://s224.photobucket.com/albums/d...pandadrive.flv
-1990 Mitsubishi Cyborg 4WD-
