Old 04-10-2009   #1
Re: Will my fricken' luck ever change?
To bad you live in Savage. Can't swing by anymore to look issues quickly.
Old 04-10-2009   #2
lol i'm closer to your work then you are..lol
-A. Swift
Old 04-10-2009   #3
santa
Boost Spike
santa's Avatar
You should have never changed your exhaust housingnto that .82?? I still have that .68 at exhaust housing on my ride. It spools very quick for a bigger turbo and makes great power. I vote to go back to the .68ar housing. :-)
Old 04-10-2009   #4
I have a divided .70 housing, with the divided manifold. Before it was an undivided .58.
-A. Swift
Old 04-10-2009   #5
santa
Boost Spike
santa's Avatar
Ahh my bad I thought you had the big housing. How come it's so laggy??
Old 04-10-2009   #6
santa
Boost Spike
santa's Avatar
Check your compression yet??
Old 04-10-2009   #7
could be the size of the turbo/mani runners, the 3" ic pipe, the q45, the jmf mani, etc. I dunno. I'm also on a 2.0l, not your fancy shmancy stroker..lol
Old 04-10-2009   #8
jhaan_dude
jhaan_dude's Avatar
Drives: a car
could it be your cam angle sensor (or position sensor)?
Old 04-10-2009   #9
tried swapping those..I don't think i've tried a black top, but I can't see how that would really effect it much (between the two)
Old 04-10-2009   #10
jhaan_dude
jhaan_dude's Avatar
Drives: a car
to me it seem like something is not gettting enough signal at 8k, try a black top....just my 2 cents
Old 04-10-2009   #11
It is at 8k under load, so it is the load issue at that rpm point, not the rpm in itself AFAIK.
Old 04-10-2009   #12
At-Least-It's-An-Evo
At-Least-It's-White-Again
At-Least-It's-An-Evo's Avatar
Drives: 98 iVTEC
just throw a 100 shot direct into it, maybe it might just sputter past 7500! If that doesn't work, try a 200 shot!
'04 Honda Ricer: stock
Old 04-10-2009   #13
on your car maybe, but not mine.
Old 04-10-2009   #14
jhaan_dude
jhaan_dude's Avatar
Drives: a car
if you do that, make sure you get it on video!!!
Old 04-10-2009   #15
jhaan_dude
jhaan_dude's Avatar
Drives: a car
whats the duty cycle you are running your injectors to?
Old 04-10-2009   #16
about 70%. We think the filter is starting to clog up, as pressure is dropping up top. I can't imagine I'm running out of fuel with my "overkill fuel pump setup".
-A. Swift
Old 04-10-2009   #17
jhaan_dude
jhaan_dude's Avatar
Drives: a car
i wouldnt think so either, and thanks nite i forgot about the free rev thing.....how many grounds do you have? and where?
Old 04-10-2009   #18
What filter are you using?
I'm using a Golan, and am keeping a close eye on it because I've heard of them failing under high boost.
Old 04-10-2009   #19
I sorta wanna test a black top and a stock ignition setup, just to compare. I know that COP works though, it's been proven, and on paper should be better..so why does this shit suck? use all 4 channels on the msd? I dunno.
Sorry for "swerving" a bit shane..the car is rather loose under boost. As I'm sure you heard..the car doesn't like to downshift to 3rd..and sit there at a higher rpm..it bucks sputters etc..then you floor it and it does the same..THEN cleans up and goes..it kinda sucks..
-A. Swift
Old 04-10-2009   #20
BTW, I can't thank enough to everyone that's helped me. Shane, Josh, John..etc. You guys have helped it get to the point it's at today..if that means anything.
-A. Swift
