Old 04-14-2009   #10
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
Re: Continuing idle problems...
I've done a bit more work. I found some leaks in the throttle shaft O-rings, those have been replaced. I crushed my BOV a bit and tested it, it isn't leaking. I tested the wires, the resistances all look good.
I've gotten rid of any loping, my idle is stable and at a decent RPM. The reamaining problem i'm having is that the idle is just rough! It idles like it has a high lift cam, and it doesn't, if that makes any sense. It makes the car shake noticeably at idle. If i set the idle too low, it shakes even more and almost seems to struggle to idle.
Should I start looking into like the oxygen sensor? Coolant temp sensor? Try another MAF? I'm not getting any check engine lights.
Anyone know what to look at for this?
Style's automotive engineer
