Old 05-07-2009   #2
Re: which way to mount balance belt tensioner?
The lip of the balance shaft tensioner pulley should be on the out side, as the lip of the pulley on the crank is twards the block, thus making sure the belt rides in the middle. You could also look at the pulley you took off to see which side the bolt head tighten onto vs the flat surface of the front cover.
