05-21-2009
#1
clicking poping and binding noise
so its about time i posted this. after i completed my 4 bolt swap. driving around i get a clicking and poping noise. sometimes i get a rubbing noise.
this happens while driving. ive checked under the car and i see nothing rubbing or any contact of moving parts.
this only happens while moving, so i tried jacking up the car and leaving it in gear to try and better pinpoint the problem but there was no noise when i tried this.
so it only happens when the cars suspension and loaded ive got no clue what this would be
ive had halon kind of check this out as well and i just cant figure it out.
when i did the 4 bolt swap is was an entire suspension swap, as well as some agx's in the back
any help would be nice as im compleatly stumped
05-22-2009
#2
Drives: white on white GSX
Re: clicking poping and binding noise
Is it possible thats the rack in pinion are bad? or thats your rear shocks are bad?
05-22-2009
#3
rack and pinion should be fine, this only started happening after doing the rear end, thats all i touched.
i guess it wouldnt hurt to throw the stockers back up there and see if that helps at all though, thanks for the idea
05-22-2009
#4
well i tried the shocks, to no avail. only other thing i can think of is that for whatever reason its the calipers making the noise.
05-22-2009
#5
Axle CV joints? Thats a common clicking noise from the rears on DSMs.
05-22-2009
#6
one of the front axles is a little loose, but the rears seem to be in good shape
05-22-2009
#7
When I was hanging out of your window, it sounded like the noise was for sure coming from up front, not the rear.
05-22-2009
#8
i just find it kind of odd this would happen after doing the 4 bolt swap in the rear. never touched the front, and it was fine before the swap.
you think a bad axle would make that kind of a noise?
05-22-2009
#9
What do all of your control arms look like? does the wheel wiggle L to R or up and down?
05-22-2009
#10
A bad CV joint would definitely make that kind of noise. When you put in the new rear axles did you check to make sure they moved freely without any weird noises or excess play? That would be the first place I would look.
05-22-2009
#11
wheels do not wiggle at all. the axles in the rear were installed already. they turned pretty freely, i installed the entire rear assembly. like the entire rear end all at once as thats how i bought it.
i tride grabing the axle and moving it around, just a very very small amount a movment on one side but nothing i would be worried about
05-22-2009
#12
The rear axles on these cars click all the time and they will usually last forever doing that and you usually won't be able to tell a good one from a bad one by looking at them or wiggling them. You just go buy new ones. If you run a welded center diff or welded VC, then those new ones will soon be clicking again.
05-22-2009
#13
so its probly not a big deal then?
06-01-2009
#14
well i went and bought an axle, got that in.
im still getting this clicking and popping noise, every once in a while i get a loud thunk as well.
going strait is fine most the time but turning slightly causes alot of noise./
anyone else got any ideas?
06-01-2009
#15
My car is down for awhile. If you want to borrow either of my axles or intermediate shaft for a couple days and swap it in just to see if the issue goes away, feel free.
06-01-2009
#16
could give it a shot, i realy think its the back end though, just that the sound it traveling up the drive shaft or something
06-01-2009
#17
3g camaro owner
Drives: 88' camaro 400hp 327 sbc
the way it sounds to me is the spider gears or the limited slip in the rear could be shot id pull the diff cover and have a look see.
06-01-2009
#18
^^ +1. If it's fine going straight, but clunks and pops going around a corner I would be concerned about the diff. That is, unless the previous owner put a clutch type LSD in it.
06-01-2009
#19
well the rear diff is welded, ill pop the cover here in the next day or two and ill take a look, ive never been in a rear diff but i guess ill find out
06-01-2009
#20
Now 20% less Racist
is your car an auto?
| Thread Tools |
| Display Modes |
Linear Mode
