Old 07-27-2009   #39
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Re: What weight oil do you use?
I would say run a little bit thicker oil. I have the original 6bolt in my car with 70k original miles and idle is around 20psi and 3k cruising on the freeway its at 75-80psi. That's with 10w30 also. The manual says no less than 11psi at idle.
-1990 Mitsubishi Cyborg 4WD-
