Old 08-14-2009   #12
ESchwanz
ESchwanz's Avatar
Drives: 97 GSX
Re: Car wont start after rebuild, HELP!
Originally Posted by OMGkiwi View Post
I also replaced the ground wire, it was all melted?
hmmm melted.. check for short?? or test the ground like this... http://www.ehow.com/video_2327356_us...light-car.html
you can use a test light to check for a short or draw on the battery by removing the negative cable and hooking the test light between the negative battery cable and the negative post... should not light up or only for a second but dim to almost being out immediately. If it lights up, then you know you have a short or draw somewhere.
