Old 04-17-2004   #2
A working stock 1G BOV will not leak at 8 psi. Are you sure the gasket/flange isn't what is leaking? From what you said, it sounds more like you have a bad boost leak. Anyways...to crush a 1G BOV put it in a vice with a rag on either side just to protect it from scratches and "crush" it just enough so the vacuum nipple barely touches the base.
