Old 10-10-2009   #2
Re: help getting running after auto to manual
IIRC, the top clutch pedal sensor is for the cruise, the bottom one is your ignition safety sensor, that can stay unplugged.
The fuel pump won't turn on with the cam sensor noticing some movement. You can use the jumper right by the fuel filter to test that the fuel pump comes on.
Do you have the ignition wire hooked up on the starter?
