Old 10-16-2009   #29
blackrosenova400
blackrosenova400's Avatar
Re: WTF: Tranny minus 4th Gear = GAY
Uh Shep does not recommend BG Syncroshift.
Taken directly from his sight
There are several gear oils that will work depending on horsepower or intended use. For most transmissions we recommend Redline MT90 or Pennzoil Synchromesh. For drag use or high horsepower cars please contact us. Please let us know if you need any Redline gear oil.
I run two quarts of Mt-90 for friction modifier, and two quarts of lightweight shockproof. Overfilled on purpose so that the gears dont pull the sump dry from using thicker lubricant. I may run Heavyweight in the summer.
Even if Shep recommended Syncroshift, I wouldn't use it but on a stock dsm.
