Old 10-19-2009   #4
Kranz
Drives: 1990 talon tsi awd and a pos mazda
Re: darn valves
The car gets compression when i pull the valves up with a pry bar by putting a little pressures on the valve springs. But the valve does not come all the way back up once the cam presses the valve down and then the motor does not have any compression. All The valves on the intake side do this. The valves on the exhaust side are all in good working order. The timing is on so it did not jump some teeth on the timing belt. I have not been able to get my hands on a compression tester or a leak tester yet. I do know that the motor does have good compression. It is like there is some thing that is on the valve stem that is not allowing the valve to come all the way back up. so I hope this info helps you help me figure this out. This is also my first DSM. Also will the g1 heads that are na turbo the same as the turbo heads cuz if I need to get a used head I know where to get a na head cheap. Your help is really appreciated
Kranz is offline   Reply With Quote
