Old 10-20-2009   #1
New FP Black HTA82 for Evo 8/9--biggest bolt-on turbo yet!
Key points:
-spools ever-so-slightly later than the standard FP Evo Red (hta76 comp wheel)
-vastly improved spool compared to a regular hta82 but with 90% the power due to smaller compressor cover means impressive powerband. 300wtq by 4000rpm.
-turbine wheel is 67mm, or 1mm smaller than a standard 35r turbine wheel.
-who knows what it'll do on pump gas, but for a high-octane build by someone willing to upgrade the bottom-end, this thing looks spectacular.
-already has gone 10.4@134mph on E85.
http://forums.evolutionm.net/evo-eng...ml#post7631669
Originally Posted by davidbuschur View Post
Well there's been a lot of rumors circulating. Speculations and expectations, today the wait is finally over.
FP is nearly ready to release the new EVO Black HTA82.
Specs on the turbo:
68 lb/mn compressor put inside FP's custom compressor cover with surge port. This is the same new cover being used on the Red's that elminate compressor sure and use a 3.25" inlet.
On the turbine side the turbo uses a 67mm turbine wheel, this is 1mm smaller than the GT35r turbine wheel. It uses a modified stock 10.5 EVO turbine housing.
The turbo all comes standard with the heavy duty actuator and the new oil feed line kit. Pricing is set at $1999.
I've been lucky enough to have one for testing and we installed it on Chris's EVO9. The car we used was a full BR build, built shortblock, Stg 3 head, AEM EMS, double pumper, ID2000cc injectors, the car is running regular E85 from a local Sunrise station.
The comparison below is this car on the Red and then on the Black. Yes, some of you will ask "What does it make on a stock car? What does it make on pump gas? What does it make at 20 psi?" My answer before it's even brought up is I don't know until it is done and tested. For now my testing has been on E85, full build and high boost, that's it and any speculation as to what it will make on a lesser set up with less boost will be answered with "LESS POWER AND LESS TORQUE".
Both of the runs below were done at 40 psi of boost. The timing was held consistent and the AFR's (using gas ratios was, 11.8:1 AFR).
The bottom line is the turbo when keeping the tune and boost "the same" was good for 64 whp and 37 ft lbs of torque. As you will see in the graph below the spool up is extremely close with very little lost in low end power. Substantial gains were made from 4500 rpm up.
Here is the dyno sheet:
Next I did some additional tuning. The boost was turned up to 41.4 psi, AFR's leaned out just a bit more to 12.0:1 and I added a few degrees of timing. The peak power then rose to 537/522.
Comparing the 537 whp/522 ft lbs to a full build with an HTA35r on a header in an .82 a/r turbine housing on race gas will make as much as 620'ish. The goal of this turbo was to make about 90% of the T3 HTA82, doing the math that means it would need to make 558 whp. The uncorrected graph from this car actually read 550-535. It's right on the money to the goals Robert at FP had.
Now, let's talk spool up. It is incredible. The new FP Black hits 20 psi at 3806 rpm! For comparison, the HTA82 build we did on Eric's car made 616/513 on Q16 at 41.54 psi, that is uncorrected numbers (no smoothing is what I mean, I do not run any corrections on the dyno at all, ever). His car his 20 psi at 4813 rpm, that's almost exactly 1,000 rpm sooner with the Black.
Chris took his car to the track Saturday, I did not know he was going, the plan was to meet him there to final tune the car, I left the car "roughed in" knowing I was going to the track with him. The AFR's were 11.6:1, boost was at 37 psi. Track conditions were not very good and he said he had no traction. Chris is an excellent driver, power shifting SOB is what he is. For the run Saturday he completely lifted to shift and just ran the car. He managed his best time to date, 10.4 at 134 mph.
Reviewing the logs I am fairly certain in good conditions and Chris driving at his best the car can run 9's.
Of course in a lightened, no headlight, no wipers, small brakes etc., equipped EVO we are going to see some really crazy times, sub-9.50's are not going to be a problem.
I've tried to give all the information I currently have. I've done a limited amount of testing on just one car. As more information comes I will share it.
Old 10-20-2009   #2
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: New FP Black HTA82 for Evo 8/9--biggest bolt-on turbo yet!
seeing all of this fun stuff makes me know that leaving my Evo stock won't happen for very much longer.
Amsoil Dealer
Old 10-20-2009   #3
F u guys. Dsmers want some shit too.
For real Looks awesome.
Old 10-20-2009   #4
Hey, if it doesn't bolt on, and you want it, make it. That's what I've been doing for years!
Old 10-20-2009   #5
^lol. I got mine. Its a holset HX35.
Old 10-20-2009   #7
DSM guys DO have bolt-ons!
I kinda think its time for FP to ditch the color scheme thing. Its nice, but now the have so many turbos...HTA Green, Red, Black...why not call them the FP HTA EVO73, HTA EVO76, and HTA EVO82, like they have the FP HTA DSM82 now. Bolt-on turbos with accurate sizes in the names.
Also, it was said somewhere that this is ONLY a compressor wheel upgrade from the FP Red. The turbine wheel is identical.
Old 10-20-2009   #8
lol. I agree with you.
But if they made a FP Brown, I wouldn't be mad.
Old 10-21-2009   #9
Originally Posted by blackrosenova400 View Post
Im considering installing and controlling a HE351VGT holset by next spring.
Those things sound crazy!
http://www.youtube.com/watch?v=HgGe1BOZl0I&hd=1
I guess they aren't the most durable though from what I hear they seem to have issues. (At least on diesels, I haven't heard of many peoploe using them on DSM's)
Old 10-21-2009   #10
Variable vein? Cool, but guys, is it so hard to make your own thread?
Old 10-21-2009   #11
Making own threads FTL.
Making every thread OT on style FTW!!
ok ok, so when you getting one of these? or are you all turbo'd out?
Old 10-27-2009   #12
10.14@136mph
http://www.youtube.com/watch?v=t1lOztnHn7Y&hd=1
Old 10-27-2009   #13
The microphone was being overloaded and the weird spooling sound was the result. They sound just like any other turbo.
Old 10-27-2009   #14
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Old 10-27-2009   #15
Thats some good driving
Old 11-28-2009   #16
http://forums.evolutionm.net/evo-dyn...-some-e85.html
Originally Posted by BenJ View Post
I received my car from Reese Tuning today and as usual they did great work. I will post up the dyno sheet in the morning, but for numbers I put down 448/390 on their mustang dyno at 29 psi and using E85. Full spool was around 3800rpms as well, making this a great turbo for the street and this turbo can very easily make more power. Thanks again to the crew at Reese Tuning! Below are my mods:
Cosworth M3's
Buschur intake
Amsoil air filter
Nisei UICP/LICP and competition intercooler
Buschur TBE w/ test-pipe
GM boost solenoid
Reese tuning intake manifold
mil.spec 65mm TB
Buschur ported exhaust manifold
Fp Black, ported with 25psi wastegate actuator
Buschur double pumper
Precision 1000cc's
EPM O2 housing
...I had a couple runs over 520 at 33 and the reason that I had them take some timing out and knock the power back down to 450 was because I'm on the stock block for now. Once my built block comes in then we will push it to the lkimit. The timing is veryconservative for E85 (daily driver, don't want things blowing up) and I will get the exact numbers from the tuner and post them up. And agin..this was on a mustang dyno identical to Buschur's.
Old 12-08-2009   #17
http://highboostforum.com/forum/show...p-and-race-gas
30psi (eek!) on pump gas:
40psi on C16:
BUT WAIT! There's more!
http://highboostforum.com/forum/show...pump-gas-power
Pump (30psi moar eek! but holy fukballs!):
Old 12-08-2009   #18
I had asked about more conservative boost on pump gas:
Originally Posted by David Buschur
Another black, the car made 421 whp on pump gas at 23 psi of boost.
Old 12-08-2009   #19
That nuts, so what is the dsm equivalent? the 3082 thing? or 3076?
I think I have finally learned to be done with bolt-on anyway, but then again I don't see upgrading past this setup unless it is terribly flawed.
BOT: this turbo looks awesome, how does it compare to yours? pretty similar right?
Old 12-08-2009   #20
To mine? BBK is ~70mm compressor wheel, this is 82mm! Way bigger.
There isn't really a direct dsm equivalent, because this evo black uses a stock turbine housing, which is twin-scroll. The advantages are pretty obvious on teh bottom-end and mid-range. The closest equivalent would probably be the HTA DSM82, which is what brad is running on his 2G, 500whp @mid30's psi on E85 on what I'm guessing is a mega safe tune since he's still on the stock bottom-end.
