Old 11-14-2009   #1
travail
travail's Avatar
Drives: EV0 8
When oil pump leak!
Well my oil pump was leaking out of oil pump gear on the timing belt side. Has any one seen this before. Because it looks like the oil pump gear was rubbing on the inside of the case and it looks like the oil pump case cover needs a gasket. Both balance shafts have been removed and there is a stub shaft on the upper oil pump gear. When I put together the new oil pump the gear's are hard to turn. But when I loosen the nut's just a little it spins good no drag. This came off and motor with 2000 miles on it. Here are some pics
travail is offline   Reply With Quote
