Old 11-23-2009   #17
viridionplague
Re: 4seasons69, poor
Uhmmm.. What? What is welded? or what are you welding?
There is a C clip that you have to take out in order to get the rod out. A bunch of the masters that i have replaced come with the wrong rod so you need to reuse the old rod, depending on which one you get. (the N/T ones are a different rod.)
currently i have a nut welded onto the pivot arm on the clutch pedal for extra room to adjust, to account for slop, im going to have the clutch pedal assembly welded so there isnt any slop in it, hence no need for the extra nut.
the new master came with a new pivot arm and rod so i dont have to worry about having the wrong pieces
