Old 11-23-2009   #3
CarPsyco84
CarPsyco84's Avatar
Re: Doesnt go into gear...Clutch, Tranny or other??
Your clutch is not releasing all the way, which could be caused by a number of things like air in the line, master or slave leaking, broken pressure plate, broken shift fork, or the clutch mechanisim in the car itself. If its a 1g, they are known for the clutch pedal mechanisim wearing out, its adjustable, but if its like mine, its too worn out, the threaded shaft on the master is not even long enough to take up the slack in the pedal.
-When in doubt, Moar RPM.
